Move to a new server
Discussion in '3CX Phone System - General' started by Flash99, Nov 14, 2017.
  1. Flash99
    Aug 3, 2017
    80
    6
    I know this question was asked many time and I already saw all the answers and all the documentation about it. But I just want to be sure.
    So what would be the correct way to move to a new server considering.
    1. Going to use a new license (bigger one).
    2. Moving from a cloud to on premises network.
    3. Public IP will change.
    4. Using 3CX provided FQDN and probably want to keep it the same. Although its not a big deal since we are not going to open the system for use from outside of the local LAN
    5. Both old and new server run Windows
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    735
    113
    None of that really matters. It's simply a matter of backup and restore. You don't need to change the key to go to a bigger license, you can upgrade the existing key. So the only thing that determines the process is if you will keep the same key or actually get a new key. Keeping the same key is easier because then it is just a straight backup and restore. Getting a new key and keeping the 3CX FQDN is a backup without key/FQDN, releasing the FQDN and then restoring with new key and same FQDN.
    https://www.3cx.com/docs/key-already-bound/
  3. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Hi Flash99,
    The answer cobaltit gave you is what generally applies. If you provide us with the version of the PBX you are currently running then a more detailed answer from our side would be possible.
  4. Flash99
    Aug 3, 2017
    80
    6
    We are using 15.5
    And we are going to use a new license file (not upgrading the existing one)
  5. apostolis_3CX
    Nov 1, 2017
    149
    15
    Since you are going to change the License Key you should take a backup EXCLUDING License Key and FQDN, proceed with the installation of the PBX and once the Configuration Wizzard starts select to restore an existing backup configuration using the backup file. If you want to use the same FQDN, before the installation you will have to release FQDN.
    Be advised that all of the IP phones that are currently provisioned remotely, will have to be reset to factory settings, released and reprovisioned.
    Also as the SP2 stable version is going to be released in a few days, i would recommend you to wait for it and proceed with the installation of the latest version.
    Flash99 likes this.
  6. Flash99
    Aug 3, 2017
    80
    6
    Thank you very much for your help
    And yes we are waiting for SP2 :)
  7. apostolis_3CX
    Nov 1, 2017
    149
    15
    I'm glad that you find my answer helpful.
