Move VAD to another server
Discussion in 'CRM / Helpdesk / App Integration' started by millsey, Jul 7, 2016.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    We are planning to move our 3CX install to another server, of course we also need to move the VAD software, projects and audio etc. can you outline how to do this? We are on the latest release of VAD with an up to date licence..
    Regards
    Millsey
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,596
    125
    Hi Millsey,
    When you backup your PBX, the VAD projects you have will be also included in the backup. So when you restore it later in a different server you should have everything ready.
    In regards to the VAD app itself, you just need to install it in the new machine and activate your license. You shouldn't have any problem with this.
    Kind regards.
