Multi-homed server
Discussion in '3CX Phone System - General' started by dan567, Jul 20, 2007.
  1. dan567
    Jul 20, 2007
    Thanks for an excellent product.
    Is there some way to "bind" the PBX to a specific local IP address?
    It appears to use whichever IP address is first in the list in the SIP headers, and this causes problems when some local IPs aren't accesible by all clients.
    Thanks in advance.
    Dan
  2. Anonymous
    Anonymous Guest
    Nope not possible yet, but it is mentioned in the feature request a few times so it might happen soon.
    Not sure how "up" you are on apache but you can bind apache to one IP address.
    That might help things for you a little.
  3. brianp
    Aug 6, 2008
    45
    I have the same problem running the 3CX with dual nics. Periodically the firewall test fails because it's resolving to the internal nic for STUN/SIP resolution. Then, again after some random time, it succeeds - resolving back out the public nic. The public nic is set to the top of my bindings list in windows server, but not sure what else i can do? Any suggestions? we are currently evaluating your product, and this is the only thing holding us up on moving forward and purchasing.
  4. brianp
    Aug 6, 2008
    45
    any word on when an update will be available that will support dual nics?
