Multi instance support
Discussion in 'Ideas' started by pat71, Jul 10, 2016.
  1. pat71
    Mar 17, 2016
    44
    Please make 3CX API support multi instance in the same application domain.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    Could you elaborate on why you would need that?
  3. pat71
    Mar 17, 2016
    44
    I have developed application using 3cx API that monitor and interact with instance 01 in 3CX PBX,
    I would like to monitor more than one instance from my mex application BUT the API do not seams to allow to create new instance for its configuration.
    you can find my application simple information
    http://www.alnayme.com/projects.aspx?proname=Mex Application for 3CX PBX
