Multi instance
Discussion in '3CX Phone System - General' started by pat71, Jun 27, 2016.
  1. pat71
    Mar 17, 2016
    44
    Do 3CX API works with multi instance application. Because i can see that the is hold statics Variables
    [DllImport("kernel32.dll", EntryPoint = "GetPrivateProfileStringA")]
    static extern int GetKeyValueA ( string strSection, string strKeyName, string strNull, StringBuilder RetVal, int nSize, string strFileName );
    So can we call to PBX From the same application?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    77
    Yes you can. When I was toying around with it some time ago I had created the following method
    Code:
    private static PhoneSystem connectToInstance(string instanceNumber)
                PhoneSystem.ApplicationName = "App Name"; //any name
                RegistryKey regKeyAppRoot;
                regKeyAppRoot = Registry.LocalMachine.OpenSubKey("SOFTWARE\\Wow6432Node\\3CX\\PhoneSystem");
                var appPath = (string)regKeyAppRoot.GetValue("AppPath");
                appPath = Path.Combine(appPath, "Instance" + instanceNumber);
                var filePath = Path.Combine(appPath, @"Bin\3CXPhoneSystem.ini");
                var value = GetKeyValue("ConfService", "ConfPort", filePath);
                var port = 0;
                if (!String.IsNullOrEmpty(value))
                    Int32.TryParse(value.Trim(), out port);
                    PhoneSystem.CfgServerPort = port;
                value = GetKeyValue("ConfService", "confUser", filePath);
                    PhoneSystem.CfgServerUser = value;
                value = GetKeyValue("ConfService", "confPass", filePath);
                    PhoneSystem.CfgServerPassword = value;
                return PhoneSystem.Root;
    Then I used to call this for all active Instances and store them in an Array and use them at will.
    Hope this helps.
  3. pat71
    Mar 17, 2016
    44
    Thank you, But is this code for V14?
    I have develop application that monitor multi instance and interact with them at the same time please see this page
    http://www.alnayme.com/projects.aspx?proname=Mex Application for 3CX PBX
    I need way that i can keep the connection active for all instance at the same time, but the config setting in the API is static so i can not create new instance of the connection for each instance at the same time. but i can do that for one at time only.
