Multi-Port routing configuration
Discussion in '3CX Phone System - General' started by cfive, Dec 21, 2009.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    Using 3cx v8.x, and Patton 4 port FXO (2).
    When configuring the ports on the Pattons, it seems that one must configure each of the 4 ports on the devices individually. Where the configuration for all 4 is the same - i.e. all connect to the same DR for office hours, and all connect to the same DR for out of office hours - it's a PITA to have to do this for every port. That's 8 configs for 8 ports, all the same routing.
    Is there a way to apply the config to all ports at once?
    Thanks - Les.
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    This was resolved by directing all incoming calls to an extension, on a tip provided by Kerry G. The forwarding rules for the extension can be used to route calls beyond.
    In this way, the ports never need changing, they always route to the extension :).
    Thanks, Kerry
    - Les.
