Multi Site install v12 vs. v14 Compatability
Discussion in '3CX Phone System - General' started by eparker@sara.com, Mar 17, 2016.
  1. eparker@sara.com
    Jan 20, 2016
    5
    We have two sites at v12 SP6.2 and are looking at upgrading to Current version v14SP3. Licensed BTW.
    1. Can we jump from one to the other, not having to install the versions in between?
    2. Do we need to migrate both site at the same time or can they coexist?
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi There
    It is possible to go directly from v12 sp6.2 to v14 sp3. Using the backup, remove, install v14 , configure and restore the v12 backup, procedure.
    If you have your v12 connected via bridges, then it is a good idea to upgrade them both at once or disconnect the bridges until you upgrade them both.
