Multi-Tenant - All Registration Requests to First Tenant
Discussion in '3CX Phone System - General' started by semose, Jun 1, 2012.
  1. semose
    Jan 11, 2012
    7
    Greetings,
    I've just switched from a single instance of 3CX on our server in our data center to multi-tenant. I restored our configuration from our standalone instance as the first tenant, and started from scratch for the second tenant. The server has two NICs, each with a different local and public IP address. Everything for tenant 1 restored correctly.
    However, every time I try to register the 3CX softphone to the second tenant, using the second IP address (either using the local address over VPN, or public IP using tunnel), the registration request shows up in the first tenants logs. I see nothing at all in the second tenants logs.
    In the 3CX softphone debug log, and I can see the tunnel is successfully created, but the request still goes to the first tenant. Not sure what to do at this point. Suggestions would be appreciated. I'd be happy to post any logs/configs needed to diagnose the issue.
    10,757
    286
  3. semose
    Jan 11, 2012
    7
    My apologies, turns out the problem was with the 3CXPhone for Windows configuration, not the server. Either I'm blind, or there is no way to configure the remote PBX server's port like in the Android version, which, as you pointed out, is not the standard 5060 for the second tenant, but rather 6060. Regardless, using the auto-provision URL for each extension made it idiot proof.
