Multi-Tenant Console For Managing Multiple 3CX Instances
Discussion in 'Ideas' started by OS Consultants, Jan 23, 2018.
Multi-Tenant Console For Managing Multiple 3CX Instances 5 5 6votes
5/5, 6 votes
  1. OS Consultants
    Jun 7, 2017
    Hi All,
    I read on 3CX's website https://www.3cx.com/blog/news/cloud-ready-pbx-multi-tenant/ that a multi-tenant console / interface was in the works for 2017. Did this slip by?
    Centralised Management
    To simplify management of 3CX instances we are planning an interface on the partner portal that will allow for centralised monitoring, backups and more of the various instances. This is on our roadmap for first half of 2017.
    Thanks!
    Coriron and Nathan Boyd like this.
  2. advanced25
    Aug 10, 2012
    19
    10
    I think what they were referring to is under "Installs" in the partner portal. There is a lot of untapped potential here though and I would love to see this turned into a complete management portal, rather than a place to aggregate a some statistics.
