Multi tenant Failover Cluster
Discussion in 'Ideas' started by ukhost4u, Jun 8, 2016.
  1. ukhost4u
    Oct 24, 2014
    Hello.
    As a provider for 3CX to partners who require to host within a data centre we are getting a lot of requests for 3CX High Availability over 2 or 3 servers. I am aware of: http://www.3cx.com/docs/failover/ this though only works on a single instance, which is actually odd as I would expect the multi tenant version to need this feature more being that it can hold a number of business phone systems.
    Anyway would move support for this feature to be added.
    Paul Hughes
    UKHost4u.com
  2. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    30
    This is very important.
    +1
