Multi Tenant Version - Which OS?
Discussion in '3CX Phone System - General' started by telecomhelp, Jan 26, 2012.
  1. telecomhelp
    Jan 20, 2010
    Anyone run this new Beta on Windows 7 Pro? I'm keen to test it but don't want the expense of a W2008 R2 license.
    Andy
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    You can test it on Windows 7 64-bit. It worked on Windows 7 Ultimate 64 bit OS without any problem.
  3. msymmes
    Nov 24, 2011
    17
    Windows 7 Pro 64 bit on a small intel i3 based motherboard working for me well !
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Why don't you simply use Windows 2008R2 Foundation Server. It has all the functionality necessary for 3CX PhoneSystem and the stability of 2008R2 Standard or Pro. Win 7 is a client OS, not server one.
    Regards
  5. Ian Joyce
    Oct 9, 2009
    51
    If you are just looking to test win 7 should do fine, if you are looking to eventually implement then you may want to look into a server OS.
  6. netswork
    netswork Active Member
    Mar 11, 2011
    577
    I believe foundation server has a client access limit that may interfer with a multi-tenant solution if there will be many phones attaching.
    Foundation is limited to 1 64 bit CPU socket and 8 gigs of ram.
    It is also limited to 30 simultaneous SMB connections. Not sure if that will effect 3cx or not, perhaps support can chime in on that one.
