Multi tenant
Discussion in '3CX Phone System - General' started by asfuture, Nov 19, 2007.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    is anyone ther that can give a answer on this question: can i use one 3CX for more than 1 client??
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Propably, but can you be a bit more specific of what you mean?
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    yes. I have 10 bussines with own numbers (inside and outside), own lines (PSTN, Sip trunking or sip accounts) i want to put this 10 on a 3CX. is that possible???
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    Yes you can.
    Take a look at this site http://www.3cx.com/phone-system/enterprise-features.html
    to compare versions that you need regarding number of lines and extensions.
    If not done already, to get a view of the system you can try the free version
    http://www.3cx.com/phone-system/download-phone-system.html
  5. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    did you mean "Branch Office Integration (Q3)" Do you know somebody, someweher where i may take a look??
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Yes. U can use one 3CX box to hosting these 10 business with their own numbers.
    There is no problem for identify the incoming calls to these 10 different business. However, you need to pay more enforce and equipments for handle the PSTN land line with FXO gateway which for out going calls.
