Multi-Tennant
Discussion in '3CX Phone System - General' started by chadsync, Feb 19, 2011.
  1. chadsync
    Dec 17, 2009
    17
    With the new versions of Exchange 2010 SP1 and such with multi-tennant built in, would be really nice to see a 3CX version of this nature. We can deploy virtualized and such, however increases management without the one-to-many appropriate for updates, custom features and such.
    Is there any of this on the horizon or more flexible options within the 3CX to come?
    11,079
    324
    Did you search through the feature requests? http://3cx.ideascale.com/ If there isn't already a similar suggestion, submit one.
  3. chadsync
    Dec 17, 2009
    17
    Hi, yes and have posted an update now...thanks
