Multicast paging through cloud server
Discussion in '3CX Phone System - General' started by Michael Knutson, May 3, 2017.
  1. Michael Knutson
    Feb 20, 2017
    16
    I am trying to set up multicast paging through 3cx installed in the cloud. I can set it up on the Yealink phones directly and it works. But if I try to use a ring group for multicast paging it does not seem to work. I have triple checked my settings and they are all right.
    Should I be able to get multicast paging working with a cloud server?
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Michael Knutson,
    Multicast paging is not possible through a cloud server. Due to its design, it only works within the same broadcast domain. To make this work, you will need a VPN between the cloud server and the remote location.
