Multicast Paging through SBC
Discussion in 'Ideas' started by mikeimpo, Feb 8, 2018.
Multicast Paging through SBC 5 5 5votes
5/5, 5 votes
  1. mikeimpo
    Dec 9, 2015
    12
    7
    With a cloud hosted server it is currently not possible to use multicast paging groups. It would be helpful if this could be setup through the SBC.
  2. Kyle Yoder
    Mar 5, 2018
  3. DocTechAZ
    Nov 17, 2017
    50
    14
    We setup multicast paging in a template change on the yealink config. it works pretty well, and the 3CX server is hosted out in the cloud.
    Brad Allison likes this.
  4. Brad Allison
    Jun 7, 2017
    67
    18
    DocTechAZ is correct, setting up multicast through phone template is the way to go, as an alternative use a multicast paging server like the CyberData Paging Server or ALGO 8301 may work for your needs.
  5. dredd0606
    Feb 14, 2018
    42
    13
    If 3CX could simply provision the listening address and allow button configuration for multicast, that is all you need. Quite simply, there is no reason why the server needs to be involved in a multicast page. Yealink and Grandstream just need the listening address configured, and a button programmed on the set to initiate a multicast page (which could be provisioned via BLF). As it sits, the only way around this is custom template, which then pulls the sets from being supported by 3CX.
    craigreilly likes this.
  6. Brad Allison
    Jun 7, 2017
    67
    18
    Correct.
  7. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,102
    166
    Ver 15.5 SP4 , has Multicast Provisioning via the Console
  8. nexigen
    Jul 8, 2013
    As soon as you select the option to use a SBC the multicast provision option is removed from the page.
    I'm currently working on moving an on-prem server to a datacenter for redundancy and scale out and getting multicast paging to work is our current issue.
  9. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    942
    152
    Well you can wait an eternity for 3CX to implement this feature, do a custom template, or get a paging adapter. You could also setup multicast forwarding over a s2s tunnel if you have that in place already for the phones.
