Multicast Paging
Discussion in '3CX Phone System - General' started by petewatterschats, Apr 12, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    How do I setup Multicast Paging
    In dial codes I have set *77 for paging
    If I select Multicast vs SIP for paging how do we setup soft phones if we use multicast. Windows, iPad and Andriod
    How would you setup yealink phones for Multicast
    Attached is a view of the Yealink Multicast Setup
    In the Yealink Multicast Tab there is a list (Table) for Multicast Listening. Multicast Address which would be the address we use when we setup a multicast ring Group. Is this correct.
    For example we could setup a warehouse ring group with 224.0.0.252 and another called Garage with an address of 224.0.0.253. Now if I enter both IP addresses in the Multicast Listing table that phone would receive a page from either of the ring groups. (Correct)
    It also has a paging List what is this used for.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    77
    3CXPhone apps cannot be paged through Multicast at the moment.
    For Yealink Phones though, this is a sample setup with all the fields filled in side-by-side.
    [​IMG]
    For the second question, yes, if a phones has more than 1 multicast IP it is listening on, then it will auto answer on both.
  3. petewatterschats
    Jan 19, 2016
    151
    How would you set up a Windows Phone for Multicast. I have not been able to find a way to setup a Windows PC for sending or receiving multicast.
    It is my understanding that Multicast needs to be done at the MAC Address level but I have no idea how to get that done
    Has anyone done this
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    You can use VLC to setup a listener - but I am not sure you can set it up to autorun with specific parameters.
    A google search for "use VLC for multicast paging" shows several articles that may be of interest.
