multime log entrys with Active calls counted toward license
Discussion in '3CX Phone System - General' started by andy, Jan 31, 2010.
  1. andy
    Oct 22, 2007
    23
    Since the update to 8.0.1824 I have many log entries like the following (see bellow)
    It´s in the log every minute but the server is not having any active calls!
    Maybe this entry should only be logged if the coungter is >0
    16:57:56.527 Active calls counted toward license limit: []
    16:57:26.527 Active calls counted toward license limit: []
    16:56:54.527 Active calls counted toward license limit: []
    16:56:22.527 Active calls counted toward license limit: []
    16:55:50.527 Active calls counted toward license limit: []
    16:55:18.527 Active calls counted toward license limit: []
    16:54:46.527 Active calls counted toward license limit: []
    16:54:16.527 Active calls counted toward license limit: []
    16:53:44.527 Active calls counted toward license limit: []
    16:53:12.527 Active calls counted toward license limit: []
    16:52:42.527 Active calls counted toward license limit: []
    16:52:10.527 Active calls counted toward license limit: []
    16:51:38.527 Active calls counted toward license limit: []
    16:51:08.527 Active calls counted toward license limit: []
    16:50:36.527 Active calls counted toward license limit: []
    16:50:04.527 Active calls counted toward license limit: []
    16:49:32.527 Active calls counted toward license limit: []
    16:49:00.527 Active calls counted toward license limit: []
    16:48:28.527 Active calls counted toward license limit: []
    16:47:58.527 Active calls counted toward license limit: []
  2. open7
    Jan 7, 2010
    30
    I also get this entry after the update.
  3. open7
    Jan 7, 2010
    30
    Check out this link about this issue. Apparently this is normal operation.
    http://www.3cx.com/forums/new-update-3cx-phone-system-3cx-call-assistant-v8-13516.html
  4. pcunite
    Apr 12, 2010
    29
    This feature needs a check to disable, logs are now useless as they are full of noise...
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
    This is far from useless, and is essential for diagnosing issues properly, with those we can see if a call is stuck, and for how long also what released it. If there was a check box to disable such logging it would hinder 3CX support.
  6. pcunite
    Apr 12, 2010
    29
    Well I meant that if I look at the log two days from now it is so full of chatter I can't find interesting details to me.
  7. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Understandable, but you could always filter it out with a good text editor. Support goes trough it on a daily basis. :mrgreen:
