Multiple alarms for an extension
Discussion in 'Ideas' started by aditel, Nov 29, 2017.
  1. aditel
    Dec 2, 2015
    23
    Hi, It would be good if you could put several wake up calls (reminder) to the same extension. So a guest can be woken different times for different days.
