Implemented Multiple browser tabs in the web management interface
Discussion in 'Ideas' started by Frank D, Mar 10, 2016.
  1. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    When you access 3cx via the web management interface (...management/MainForm.wgx) only one tab is working. If you open multiple tabs, they will always show the same thing.
    I often have to move back and forth between different views (extensions-list, phones-list, some group permissions, a single extension ...) and the load time for some of those is quite high. Sometimes you really have to look at two views at the same time. Right now, I sometimes have to make notes (like IP; MAC, Password, DID) before jumping to a new view :S .
    It would be really great if you could support several tabs. Managing things could be much more convenient and faster 8| :D .
    I guess that their might be a performance issue, having multiple tabs open, but it is up to the user to act responsible (or up to the priorities of the processes).
    Keep up the great work
    Frank
  2. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    Yes, thanks for this tip. This is a nice workaround. I am already using it sometimes.
