Multiple Connections
Discussion in 'Windows' started by datalab, Aug 22, 2010.
  1. datalab
    Aug 22, 2010
    Is it possible to have more than one connection active at a time?
    I've configured 2 different connections, but they cannot be active simultaneously. Any ideas?
    Marian Yordanov
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    Hi Marian
    Current released version supports only one active connection at a time, so it's nothing to do. But soon we will release a new version, which will allow multiple simultaneous active accounts.
    Regards
    vali
  3. datalab
    Aug 22, 2010
    Thank you for he prompt answer.
    I know it is difficult to estimate, but do you have an idea for the time frame (months ahead).
    Marian Yordanov
  4. Vali_3CX
    Dec 12, 2008
    1,531
    69
    I don't think it's about "months", in my opinion next month it will be released.
    Regards
    vali
  5. datalab
    Aug 22, 2010
    Thanx again!
    So far, great product and timely support.
