Multiple ddi's not working with provider
Discussion in '3CX Phone System - General' started by future-data.biz, Feb 19, 2008.
  1. future-data.biz
    Oct 15, 2007
    26
    Dear All,
    I have a VOIP provider with 10 x DDI's. These DDI's are registered to the VOIP provider through 3CX.
    I have asked the Provider to send me the DDI number in the invite message, which is happening. When I try and ring any other number in the DDI range, I get an "authentication failed for SipReq:Invite ...." message. Also, the error is showing "unidentified incoming call".
    If I change the source identification to match just one DDI, it works. How can I change the source identification to match all or any of my DDI's coming in from the provider.
    If any of you have managed to overcome this, please could point me in the right direction.
    Many thanks in advance
    Kind regards,
    Rob
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    Hi Rob,
    Unfortunately you will have to use a different variable to identify the inbound call. The easiest is to use a supported provider.
    If not you will have to find a field that the provider uses in each call regardless to which it is addressed. Most providers allow the use of the auth ID of the account or the IP or something similar.
  3. future-data.biz
    Oct 15, 2007
    26
    Will Do....I think there is a way..I will post once I have a solution
    Regards
    Rob
  4. future-data.biz
    Oct 15, 2007
    26
    Dear All,
    I got this resolved with the help of my provider and with Nicks comments below. The Provider is http://www.voiceflex.com .
    The provider made changes to the invite messages they were sending (which is now totally compatible with 3CX as you can now use a generic SIP trunk to setup a voiceflex account).
    Regards
    Rob
  5. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    thanks for the info
    regards
