Multiple DID numbers
Discussion in '3CX Phone System - General' started by pd2006, Mar 25, 2008.
  1. pd2006
    Nov 29, 2007
    I'm new to 3cx so please bear with me. Is it possible to do the following with free 3cx.
    1. is there any way that a did can ring on a group ring as I've tried it now and it only rings on 1 phone.
    2. Is there any way that I can show the name of the company in the line status as well as the number.
    3. is there any way that a screen pop up can be display when some rings a number so I can see what company is required.
    I have loads of questions so thanks in advance for your help.
