Multiple DID on same trunk V15
Discussion in '3CX Phone System - General' started by jdale, Sep 9, 2016.
  1. jdale
    May 8, 2015
    21
    I have a single account with my SIP Provider Anveo.
    I have 2 DIDs with them on this trunk. One is our main office number and the other will be a direct line to a dedicated phone.
    I have added the DID to the trunk and assigned it to the extension in question.
    If I call that DID directly I get forwarded to the main IVR just like the main number?
    Would the DID assignment not take presedence over the Trunk settings?
    11,086
    325
    Have you confirmed that the correct header (3CX is aware of the DID number), is being sent by your provider, for that number, and, that all DID settings (for both numbers) in 3CX are correct.
    "Would the DID assignment not take presedence over the Trunk settings?"
    If you have told the trunk, as a group, to send calls to one destination, then, I believe that will take precedence. You may need to treat all calls as DID's (no trunk group routing).
