Multiple email addresses for one extension
Discussion in '3CX Phone System - General' started by daktur, Mar 13, 2017.
  1. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    Hi all,
    Is it possible to set multiple email addresses to one extension?
    Tried using either , or ; and the system did not accept it.
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    GiannosC_3CX likes this.
  3. GiannosC_3CX
    GiannosC_3CX Guest
    Hi daktur,
    You cannot add multiple emails addresses to one extension but as mentioned above by 3CXusername, you can add a central email address which is a distribution list and you can add several accounts on that list.
  4. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    Thank you for your suggestion, it will be really useful :)
