Multiple email recipients for reports
Discussion in 'Ideas' started by the60, May 9, 2017.
Multiple email recipients for reports 5 5 1votes
5/5, 1 vote
Tags:
  1. the60
    the60 New Member
    Oct 21, 2011
    117
    63
    Please consider enabling the ability to have multiple email recipients for on-demand and scheduled reports. Limiting a report to a single email means potentially having to set up multiple, identical reports for multiple recipients.
    (Yes, I know all about email enabled distribution lists. Some times, the end user doesn't!)
    Also on the same subject, for faster report setup, enable the ability to select the extension of the person(s) who should receive the emailed report. More accurate & faster than typing in an email address.
    Thanks!
  2. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    Hello there,
    We are supporting multiple email recipients for on-demand and scheduled reports.
    When you create a call report , on the email field you can put multiple email addresses separated by comma.
  3. the60
    the60 New Member
    Oct 21, 2011
    117
    63
    Greetings. I'll test & advise. But this is in contradiction to support ticket # 139370, created May 9 2017.
