Multiple extensions on one GXP2000
Discussion in '3CX Phone System - General' started by KenC, Apr 1, 2012.
  1. KenC
    Mar 29, 2012
    85
    Can I register more than one extention to one physical gxp 2000? (the goal is to be able to use Myphone client with extentions that are for now unregistered.
    Thank you.
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    No you can only register one extension per handset. What exactly are you trying to accomplish?
  3. leejor
    10,779
    286
    According to the manual, http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf you can register up to four extensions/lines on that model. Am I missing something?
  4. KenC
    Mar 29, 2012
    85
    I have incoming calls routed to a call assistant; caller makes selection and is directed to extensions. I want to be able to use myphone client with those extentions, which are now not registered because I hav just the one gxp2000 sip. If I could register those extensions to the other accounts on my gxp I could access them with myphone.
    Thanks to everyone for your help!
  5. willow
    willow Member
    Mar 1, 2011
    471
    the phone itself should be able to handle multiple accounts. however you will not be able to use auto provision as it will not let you have more then one account unless you make a new template stating as such. myphone, I think will only monitor one account. you would need a session of myphine open for each extension.
  6. KenC
    Mar 29, 2012
    85
    Great. Thank you. Having trouble provisioning the extra accounts of the gxp2000 because they all have the same mac. Does 3cx allow provision ing of more than one extension at the same mac?
  7. leejor
    10,779
    286
    I've seen the MAC issue come up before. As willow suggests, you will probably have to manually provision any additional lines on the set.
  8. KenC
    Mar 29, 2012
    85
    so theres a way to provision more than one extension per MAC?
