Multiple Extensions on one phone
Discussion in '3CX Phone System - General' started by ken.stigler, Jan 13, 2016.
  1. ken.stigler
    Jan 13, 2016
    New to the 3CX system..
    have a question that I don't know how to resolve.
    The president's admin would like to have a second line on her Yealink T48 so that she can answer the president's calls if he is on the phone, or if he is in her office.
    Is that something that can be done?
    I can obviously get a busy lamp field on her phone, but that doesn't help her answer or call from her phone on his line..
    Thanks in advance for any direction.
    Ken
    11,105
    329
    The set appears to support multiple lines (SIP accounts) , but, may require a custom (manually edited) template /configuration file, to add the additional line(s). I'm not certain that it can be done from the PBX when the set extension is "created". Someone more familiar with that set may have additional information, or a template example.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    custom template with manual fields filled in for account 2 is probably easiest way to go with any phone that supports multiple accounts, as the Yealinks do.
