Multiple extensions on same phone without forwading
Discussion in '3CX Phone System - General' started by cmdias, Mar 22, 2017.
  1. cmdias
    Feb 13, 2017
    32
    Hi Guys,
    Quick question.... a customer asked me to link up to 4 extensions on the same phone (Yealink t27)... he really wants the extensions to be treated as unique entities (no forwading)..... is this even doable with 3cx ???
    He needs that person to answer differently to each extesion... no matter where the call comes from....
    any ideas ?
    10,757
    286
    If a VoIP set has multiple line keys, then any, and, or, all, can be assigned to unique, or the same, extension numbers if desired. In some cases this may require manual programming, or a modification to a template.
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    Yes you can do this with the T27 but you have to manually configure the additional 3 accounts and then assign DSS keys to them.
    A much simpler way to do this in 3CX is to setup the additional extensions as "ring groups" with the first extension as the destination. 3CX will pre-pend the name of the ring group on the incoming call and the person can answer appropriately.
    You can even have all four go to different voicemail boxes if unanswered, though I highly suggest using the voicemail to email feature for any additional extensions so that they don't have to check four separate mailboxes.
