Multiple extensions on the same client - possible?
Discussion in '3CX Clients' started by Razva, Jun 8, 2017.
  1. Razva
    May 7, 2017
    30
    Hey,
    I need to use two extensions from the same client, because I need to call outside using two different DIDs. Is it possible to do so?
    Thanks,
    Razvan
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,444
    61
    No, it's not possible due to MyPhone-related ops - maintaining two contact books, two presence lists, two missed calls lists, two MyPhone statuses etc...
    teldata1 likes this.
  3. daktur
    daktur New Member
    Oct 15, 2015
    225
    7
    You can set a prefix to choose which outbound rule / did you will be using.
    Have you tried?
