Multiple Extensions settings change
Discussion in 'Ideas' started by telin, Dec 1, 2015.
  1. telin
    Jul 28, 2015
    It is really annoying, that sometimes some basic options for extensions is greyed out, when you select multiple extensions.
    I understand, that this is done, because some of these functions, like basic extension info (Name, Authentication ID) should not be allowed to avoid setup conflicts, but there are a lot of things that are setup on multiple-extension basis.
    Outbound Caller ID (as we are always have to punch it in for each extension, it really take a lot of time)
    Management console access (sometimes it is needed to allow customer to work on their own extension, let's say)
    Extension rights (for example, when changing the group membership of the whole department)
