Multiple extenstions, 2 systems & push
Discussion in 'Android' started by Stringly, Dec 16, 2015.
  1. Stringly
    Dec 16, 2015
    Good morning all,
    My work is currently running v12 of 3CX (not yet push enabled) and I have set up v14 at home (push enabled)...currently running 2 separate Android apps on my S5.
    Our IT guys are discussing the possibility of upgrading my work system to be v14 (presumably with push enabled...TBC) and I was wondering whether anyone had managed to successfully have extensions from 2 different v14 systems, both push enabled, running on their Android app?
    If so...that's great as it means I'll still be able to have my home phone running in the background whilst I have access to my work extension.
    If the above is possible, is it possible to assign different ringtones for each different system extension so that I know whether it's my work phone or home phone ringing?
    Thanks in advance :)
