Multiple Gamma Trunks
Discussion in '3CX Phone System - General' started by EduTech, Sep 21, 2017.
Tags:
  1. EduTech
    Sep 21, 2017
    Good day
    I am looking at hosting 3cx for several sites but would like to place restrictions in the number of simultaneous external calls for each site depending on their size.
    Would the best option to be have several trunks each with the required number of channels, and if so, is it possible to have multiple gamma trunks, as it mentions on the template as "Single Instance Only".
    Thank you
  2. AndreasPo_3CX
    AndreasPo_3CX Support Team
    Aug 10, 2017
    138
    12
    Hello @EduTech ,
    The best option would indeed be to have several trunks each with the required number of channels.
    You can use multiple Gamma trunks as long as they have different DIDs.
    Hope this helps!
