Multiple Identites for Softphone
Discussion in 'Ideas' started by das, Dec 10, 2015.
  1. das
    das
    Dec 8, 2015
    14
    more than one active SIP-Lines in 3cx Windows or smartphone apps
    For accounting purposes we have several extension groups.
    Some of our employees have two or more extensions on one phone for switching outgoing calls to the appropriate group.
    With a deskphone this is no problem, simply pressing the line which is required.
    With Windows or smartphone apps you have to go to settings, activate the required line and go back to dial.
    I think it should be possible to implement such a feature - even the free client of Zoiper has this feature.
    Regards,
    Axel
  2. 3cxsbx
    Nov 18, 2015
    28
    I see a lot of users including myself to use more than one identiy in the softphone. Unfortunately only one can be active at a time.
    I would like to be able to have more than one identity active (at least for push e.g). if not possible another solution may be to activate identities on a schedule (e.g. business identity during business hours and out of office emergency identity or home identity)
