Multiple licenses for simultaneous calls?
Discussion in '3CX Phone System - General' started by conversys1, Jul 8, 2016.
  1. conversys1
    Jun 6, 2016
    Hi everyone,
    Just a quick question. Can you combine multiple licenses to add more simultaneous calls? For example, if you only need 20 simultaneous calls, could you use a License for 4 and a License for 16?
    Thanks in advance,
    RK
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Just one license per pbx. If you need 20 SC, you will have to go with a 32 License.
    Regards,
    Allen
