Multiple line registraions on 3CX soft client
Discussion in 'Windows' started by Discovery Technology, Jun 11, 2008.
  1. Discovery Technology
    Apr 19, 2008
    278
    Does anyone know how to setup (or if this is currently possible) registrations to multiple extensions on a single 3CX voip client?
    I have a reception setup with a headset and the soft client who wishes to be able to answer 1 line, then place it on hold and pick up the second all from the one client - this is possible on handsets as they support two lines - can the voip client also support multiple lines?
    Thanks...
  2. Discovery Technology
    Apr 19, 2008
    278
    Thanks Matt,
    I'm assuming the soft client doesn\t require any settings for this.
    The ring group suggestion would be handy also if you have the time to chuck it into this for forum.
    On a handset would you configure line 2 with the same extension details as line 1, or configure it as a second extension then setup a ring group to forward to the 2nd if the first is busy?
    Cheers, Brendan
  3. Discovery Technology
    Apr 19, 2008
    278
    Thanks Matt - awesome... you'll be making some receptionists very happy over here :)
    Thanks, Brendan
