Multiple outgoing numbers
Discussion in '3CX Phone System - General' started by ManyJoe, May 6, 2017.
  1. ManyJoe
    Apr 11, 2017
    6
    I have a Twilio SIP Trunk connected to my 3CX V15.
    The Trunk has four phone numbers, but Im using only one now, and works fine for incoming and outgoing from 3CX.
    Question: Can I configure 3CX to use other numbers when making outgoing calls?
    I need to use number1 when calling customers, and number2 when making personal calls, etc etc.
    (Im using the 3CX client on iphone)
  2. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    3CX can do it. Just depends on what Twilio permits.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,968
    181
    twilio would need a second trunk connection with a separate outbound number... and an outbound rule for each.
    for instance, calls starting with a 9 prefix would use Trunk 1 with outbound number 888-777-6666 and calls starting with an 8 prefix would use Trunk 2 with outbound number 888-777-5555.
    but Twilio would have to support multiple registrations.
  4. datamerge
    datamerge New Member
    Nov 19, 2014
    169
    19
    I have found that some sip trunks can be set up twice with one to register and the other set to outbound only, or do not require on type of authentication. You use outbound rules as Craig said. Inbound calls come in on the registered trunk.
