Multiple profiles
Discussion in 'Windows' started by cold80, Mar 23, 2010.
  1. cold80
    Mar 23, 2010
    Can I receive phone calls from multiple profiles? I have set up 2 profiles but it seems just one is active...
    Thank you
    cold
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    no at this time you can only register one extension to the VOIP phone at a time. if you need multiple extension number to point to one extension then you should forward them to the main extension.
  3. t4mack
    Jan 19, 2010
    56
    It all depends on the type of phone you have. Some phones support more that one sip profile. You just have to make sure that the profile is turned on on the phone. What type of phone are you using?
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Its the 3CX VOIP phone section, so i believe hes using the VOIP phone unless he posted in an incorrect location.
  5. t4mack
    Jan 19, 2010
    56
    If that is the case. Then only one profile could be selected at a time.
