Multiple registrations seen on VoIP.co.uk
Discussion in '3CX Phone System - General' started by adam.crisp@voip.co.uk, Nov 12, 2007.
  1. adam.crisp@voip.co.uk
    Nov 12, 2007
    We have customer using your product, and we have had a few support queries come in.
    We have installed the free version of your product as follows
    1 SIP phone, extension 200, actual device is a SNOM 360
    1 Digital Assistant extn 800, plays a file and pressing 1 transfers the call to exten 200
    1 VoIP provider defined; beta.voip.co.uk username/password
    Inbound calls are configured to route the call to extn 800 (DA)
    STUN is disabled. This is a requirement of using VoIP.co.uk
    We are seeing the following SIP AOR for the PBX: i.e. it is registering multiple times, where this should be a single entry.
    note this results in us sending multiple Invites to the PBX on an incoming call. Another issue is when the call is answered by the DA, we hear the audio file played multiple times. The PBX should answer the first Invite, and respond back to us with a loop detected message on the other invites for the same call.
    platform / public IP / registration / weight / expitarion / UA
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=8f12802c207aa000 12/11/07 09:54:57 1.00 5 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=2b256e0ae92c7970 12/11/07 09:54:57 1.00 5 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=8e0999345948dd08 12/11/07 09:55:18 1.00 20 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=a716481d0d7ae55a 12/11/07 09:55:39 1.00 35 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=8a3442398b020557 12/11/07 09:54:37 1.00 49 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=d868cb4c81696849 12/11/07 09:54:58 1.00 64 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=e86da67a36599179 12/11/07 09:55:19 1.00 79 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=1b65f85faf3ebb58 12/11/07 09:55:39 1.00 94 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=2b5bde4f0a180964 12/11/07 09:54:37 1.00 108 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=bb7126137e4d1f34 12/11/07 09:54:58 1.00 123 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=8174844a33201260 12/11/07 09:55:41 1.00 138 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=245ce042037ddf7c 12/11/07 09:55:41 1.00 138 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=a754cb7476476e3c 12/11/07 09:55:40 1.00 138 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=a46dae76ed32be18 12/11/07 09:55:40 1.00 138 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=cc49044b5c69c564 12/11/07 09:55:17 1.00 138 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=6b70ef2e917ece42 12/11/07 09:54:46 1.00 139 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=69157038ec1cf133 12/11/07 09:55:46 1.00 140 3CXPhoneSystem
    Beta (IP) 87.127.89.138:1027 sip:776437@172.29.0.250:5060;rinstance=d9180e512c2ea44f 12/11/07 09:55:46 1.00 140 3CXPhoneSystem
  2. Philco
    Philco Member
    Nov 10, 2007
    364
    Is this issue of multiple registrations being addressed, as this causes multiline ringing on multiline phones that are connected through the 3cx server.
    I appreciate that V3 may not be developed further but V5 isnt stable yet of course install and leave.
    Phil
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,309
    This issue has been fixed when V5 yet been in beta stage. V3 has no such issue as far as I know.
  4. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi Archie thanks for the reply. The first post in this thread from Adam describes the issue when using voip.co.uk as a provider. I can confirm it ocours on tests I have done too, on two V3 systems we have running using voip.co.uk as the provider. Adam is part of voip.co.uk by the way.
    Phil
  5. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi Archie, just installed V5 I can confirm Version 5 is ok on voip.co.uk and no multi registration so far.
    Phil
