Multiple SIP accounts on the same time
Discussion in 'iOS' started by den20pl, Aug 12, 2013.
  1. den20pl
    Aug 12, 2013
    Hello everybody,
    Is possible to have multiple SIP accounts registered (active) on the same time ?
    Pawel
    11,117
    329
    Not that I'm aware of.
    Just to add a bit...
    The "general" thinking, is that you are going to be using the 3CX phone in conjunction with the 3CX PBX. The combination gives you a lot of flexibility. The PBX, is where you would register more than one VoIP provider, then set-up outbound rules to direct calls to the appropriate trunk.
    While some versions will work with a VoIP provider, well...consider that a bonus. In the the newer 3CX phone versions they are moving away from a universal version, to the point where the design is such, that some, will only work with a particular version of the 3CX PBX.
