- Joined
- Oct 7, 2007
- Messages
- 5
- Reaction score
- 0
Multiple sipgate registrations with “random” sip id´s f
I registered sipgate.at successfully. In- and outbound calls are possible. However, 3CX registers all the time with different SIP ID´s. Hence, sipgate seems to identify each registration as different SIP end node (telephone). As you can see the rinstance=SIP ID changes all the time. Moreover, 3CX registers very often even without in or outboud calls. It seems it ignores the SIP registration timer which is default 3600 seconds. After 50 registrations sipgate.at deny new registration attempts. Is it possible to provision a static SIP ID for lines. Why does 3CX change the SIP ID on lines all the time. The SIP ID is usually static it is on a Cisco phone 7960 typically the type of phone and firmware version loaded. Thanks for you help!
Sipgate registration log
3CXPhoneSystem 07.10.2007 12:02h 195.170.84.122:1042;rinstance=03753f1b174cb475
3CXPhoneSystem 07.10.2007 12:10h 195.170.84.122:1042;rinstance=054add2c98615078
3CXPhoneSystem 07.10.2007 12:06h 195.170.84.122:1042;rinstance=0e1cdc6c453c0c71
3CXPhoneSystem 07.10.2007 11:44h 195.170.84.122:1042;rinstance=1912477b1058037d
3CXPhoneSystem 07.10.2007 12:02h 195.170.84.122:1042;rinstance=1c40213b78174465
3CXPhoneSystem 07.10.2007 12:04h 195.170.84.122:1042;rinstance=294ef35e090b9834
3CXPhoneSystem 07.10.2007 12:18h 195.170.84.122:1042;rinstance=3472016a326ed67f
3CXPhoneSystem 07.10.2007 11:34h 195.170.84.122:1042;rinstance=362055659f195554
3CXPhoneSystem 07.10.2007 11:50h 195.170.84.122:1042;rinstance=390c15421f16e116
3CXPhoneSystem 07.10.2007 11:30h 195.170.84.122:1042;rinstance=3a34a8611e0cb65d
3CXPhoneSystem 07.10.2007 12:22h 195.170.84.122:1042;rinstance=3b0347263f27b358
3CXPhoneSystem 07.10.2007 11:48h 195.170.84.122:1042;rinstance=435c487d203a8246
3CXPhoneSystem 07.10.2007 11:32h 195.170.84.122:1042;rinstance=481d8e2ad85ba669
3CXPhoneSystem 07.10.2007 11:34h 195.170.84.122:1042;rinstance=4954a17b4b0f7c3d
3CXPhoneSystem 07.10.2007 12:16h 195.170.84.122:1042;rinstance=4a17a1584e3d9666
3CXPhoneSystem 07.10.2007 12:16h 195.170.84.122:1042;rinstance=4d734f505075662c
3CXPhoneSystem 07.10.2007 11:52h 195.170.84.122:1042;rinstance=590d031e4e6f254b
3CXPhoneSystem 07.10.2007 11:58h 195.170.84.122:1042;rinstance=6334b56e107f6a70
3CXPhoneSystem 07.10.2007 12:06h 195.170.84.122:1042;rinstance=6354525c6f58a53d
3CXPhoneSystem 07.10.2007 11:42h 195.170.84.122:1042;rinstance=67296c37b2194334
3CXPhoneSystem 07.10.2007 11:56h 195.170.84.122:1042;rinstance=6900ee2bcc654149
3CXPhoneSystem 07.10.2007 11:36h 195.170.84.122:1042;rinstance=6c022b0d863f8915
3CXPhoneSystem 07.10.2007 11:34h 195.170.84.122:1042;rinstance=717d17694103885e
3CXPhoneSystem 07.10.2007 12:08h 195.170.84.122:1042;rinstance=7409e733381a7f57
3CXPhoneSystem 07.10.2007 12:18h 195.170.84.122:1042;rinstance=7931440420005c38
3CXPhoneSystem 07.10.2007 11:30h 195.170.84.122:1042;rinstance=8346a21ea150175a
3CXPhoneSystem 07.10.2007 11:41h 195.170.84.122:1042;rinstance=8824fd2a543de20e
3CXPhoneSystem 07.10.2007 11:36h 195.170.84.122:1042;rinstance=883f3624560ee173
3CXPhoneSystem 07.10.2007 11:38h 195.170.84.122:1042;rinstance=8a5e08143e19137f
3CX log after 50 successful registrations = 50 devices registered in sipgate.at for one PBX
11:07:23.424 ClientRegs:nFailure [CM113006] Registration of sip:[email protected] has failed; reason=Service Unavailable 11:07:23.127
