Multiple Static IP's
Discussion in '3CX Phone System - General' started by Norman, Sep 25, 2017.
  1. Norman
    Jun 27, 2017
    8
    We initially installed v15.5 (Pro license) with a single ISP with a static IP address.
    We have now added a second ISP (as a failover) and have static IPs from this ISP as well.
    In the past we used 3CX v9 and just used STUN to resolve the external IP address.
    Is there a way to either add the second static IP, or have 3CX automatically fail the external FQDN over to the new IP when the traffic fails over?
    (We do have occasional outages on one ISP or the other.)
  2. Archie Frederic
    Jan 31, 2017
    69
    I'd suggest that in that case you could use Dynamic IP Address during the installation
  3. Norman
    Jun 27, 2017
    8
    Does that mean we have to go through the install all over again? Is there a way to change it without re-installing?
  4. Archie Frederic
    Jan 31, 2017
    69
    Yes, but you do not have to reconfigure all over again. you could always backup your current configuration then restore it on your new installation. By the way I'm not sure if it is possible to change from static to dynamic IP on an installed pbx.
  5. pact
    pact New Member
    Dec 16, 2009
    163
    30
    In Settings -> Network Settings.
    Change your IP address to 'Dynamic', then it will use STUN again and will automatically periodically check your public IP and update it's records (including the 3CX FQDN) to match the new IP.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Like @pact mentioned you can change the option from Static to Dynamic but it will require you to restart services for this to take effect.
    Have in mind that the PBX checks for changes every 20 minutes by default and if you are using a 3CX FQDN the DNS entry will automatically update. However this might take up to 6 hours and the DNS propagation might take even longer so you might have some down time during this time. It is always recommended to use a static public IP address.
  7. Norman
    Jun 27, 2017
    8
    Is there a way to use multiple static public IP's?
    We have two ISP's with static IP's from both of them for a reason. We are currently experiencing an outage with the one we use as our primary. They are having routing issues, so it is even effecting our firewall's ability to detect the issue and we had to manually force the firewall to fail over. We have 5 static IP's from both ISP's and currently only 1 IP from our primary ISP is working. The others are not (3CX is not on the 1 address that is working so our phone system would currently be down if we were open today.)
    We used to use Ver 9 and this was not an issue because we just used STUN without an external FQDN. It seems like 3CX's attempt to force most everything to FQDN did not take into consideration ISP issues and outages.
