MULTIPLE SUBNETS, SOFT PHONES, HARD PHONES - HEEEELP!!
Discussion in 'Windows' started by craigbramley, May 15, 2008.
  1. craigbramley
    May 15, 2008
    We have downloaded the Enterprise Version and activated a Demo trial.
    We have set up a test lab consisting of 2 x Grandstream BT200 telephones, 1 x Server, 1 x Client, 1 x Multisubnet Firewall (Watchguard Firebox Edge)
    The 3CX Server is on IP Address - 10.1.20.2
    The First BT200 is on IP Address - 10.1.20.1
    Gateway Address is - 10.1.20.254 (Watchguard)
    The 3CX Client is on IP Address - 172.26.20.2
    The Second BT200 is on IP Address - 172.26.20.1
    Gateway IP Address is - 172.26.20.254 (Watchguard)
    We have set up the Tunnel on the 3CX Client which connects.
    The First BT200 (10.1.20.254) Can succesfully call 3CX Client (172.26.20.2) and vice Versa.
    But we cannot get the second BT200 (172.26.20.1) to communicate with 3CX Client (172.26.20.2) and therefore unable to call or receive calls on it.
    We have followed the instructions but can't figure out what is going wrong, the phone is just dead when you pick it up?
    Any ideas? just in case we have missed something.
    Craig
  2. cyberspot
    May 12, 2008
    87
    Hi craig
    I have a watchguard and i think by default denies traffic from one interface to another
    Try to see in traffic monitor if it blocks sip packets
    try with a voip client to exclude that the phone has a problem
  3. craigbramley
    May 15, 2008
    The Firewall is not blocking packets and the 3CX Client (Software based) can make and receive calls over the subnets no problem.
    The issue is getting the Hard Phone to talk to (or through) the 3CX Client (Software Based) - Which are both on the same Subnet.
    Has anyone got any tips in this area?
  4. cyberspot
    May 12, 2008
    87
    Craig
    In 3cx server what do you see is the phone registered?
  5. craigbramley
    May 15, 2008
    I see the IP address of the The 3CX Client is on IP Address - 172.26.20.2 is reqisterred.
    Not the the Second BT200 on IP Address - 172.26.20.1
    Thanks so far.
    Craig
  6. craigbramley
    May 15, 2008
    Just to clarify, it is this part of the setup that I am struggling with:
    3cx.com/support/3cx-tunnel.html - https://www.3cx.com/docs/3cx-tunnel-session-border-controller/ new link
    Using the tunnel, the software (client) computer configures fine, and I can make and receive calls over subnets.
    But trying to get the hard phone to use the scx tunnel, we can't seem to get it working, I have followed the above instructions and the phone is just not working.
    #6 craigbramley, May 19, 2008
  7. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,940
    250
    I would not use a BT 200, first of all, its not a supported phone. When you have one way audio its almost always a firewall issue.
    If you want to figure it out yourself use the server status log to check what ips are seen by the PBX, use the firewall checker to check ports are free. You can also use the wiki at wiki.3cx.com for more information.
    Though it seems that you have a relatively complex setup that would benefit from commercial tech support.
