Solved Multiple time conditions
Discussion in '3CX Phone System - General' started by ip46, Dec 5, 2017.
  1. ip46
    Apr 27, 2016
    Is there any chance 3cx support multiple time conditions.
    I have three queues which works with the global office hours. Mon - Sat 9.00 to 17.00
    But i want on Saturday when someone enters the first queue and is 15.00 to hear that the support departure is closed.
    I have many clients who want this feature and i can not give them a solution.
    The solution with the dummy extension is NOT a solution because then i do not have correct reports.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    May be you can create dummy extensions and use exception rules to forward calls to different destinations, based on time.
    Other option is to create a project using CallFlow Designer.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,255
    203
    #3 Saqqara, Dec 5, 2017
  4. ip46
    Apr 27, 2016
    Thank you very much. I already create a time based project with CFD.
    It seems to play well.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
    Glad the issue has been resolved and thank you for sharing your solution
