Multiple voicemail greeting management from phone
Discussion in 'Ideas' started by giwm, Sep 8, 2017.
  1. giwm
    giwm New Member
    Sep 27, 2016
    When a user goes on vacation, they want to record a vacation greeting that can easily be switched back to the default when they return. However, there's currently no way for an end user to do this.
    I'd like to see the voicemail menu options expanded so you can natively record a greeting for each status type. For instance, you'd choose "Away" and it'd save it as vmgreeting_away.wav and set the away greeting to that file. Now when a users changes their status to away, that greeting is used.
    Wash, rinse, repeat for all availability options. Not sure why the voicemail management from the phone plays second fiddle to the web client.
