Multiple webcam support on WebMeeting
Discussion in '3CX Phone System - General' started by Vahur, Jan 29, 2018.
  1. Vahur
    Jan 20, 2017
    10
    Hello!
    Is there possibility to select webcam on 3X WebMeeting when multiple webcam are connected to PC?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @Vahur
    Please note that it is through the browser that WebMeeting can use your PC's camera. Therefore you can select a camera through the browsers settings. In Google Chrome which i use, when a WebMeeting is started there is a little camera icon on the address bar which can be clicked. Once clicked, you will be presented with permission settings regarding the camera and microphone . You can then click manage and on the next screen click camera. You can select a different camera from there.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    A setting to natively control this from inside WebMeeting rather than having to do it from Chrome's settings is something we've wanted to add for a while now. We're hoping this will be something we will add eventually.
