Multiple Yealink Expansion Modules Support
Discussion in 'Ideas' started by Brad Allison, Dec 12, 2017.
Multiple Yealink Expansion Modules Support 5 5 2votes
5/5, 2 votes
  1. Brad Allison
    Jun 7, 2017
    67
    20
    add ability to provision more than one expansion module like the EXP40 with Yealink.
    jj1 likes this.
  2. jj1
    jj1
    Feb 23, 2012
    24
    Yes please!
