multiples SIP accounts
Discussion in 'Windows' started by evcz, Sep 10, 2008.
  1. evcz
    Sep 10, 2008
    Is possible to associate multiple SIP accounts at the same time?
    and have them all avalable?
    For now I can just choose which one to connect :(
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    Yes You can
  3. evcz
    Sep 10, 2008
    wow :O
    How can I do that?
    I added the config of 2 SIP accounts, but I can only switch from one to the other... but when I switch to the second one, the first one get "de-registered" am I doing something wrong?
    thank you
  4. evcz
    Sep 10, 2008
    yeah that's what it's appearing to me too after two days of "clicking" around :/
    didn't saw any difference even on the business version about that....
    I think I'll have to go back to ekiga :(
  5. galal202
    galal202 New Member
    Jun 23, 2008
    235
    What the meaninig of sip account ?
  6. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    I guess I'm not sure exactly what you are looking to do.
    When I set mulitple identites in my SNOM 370 I can be registered as 2 different extensions simultaneously and receive and make calls without issue on both.
    Mike
  7. evcz
    Sep 10, 2008
    I want to do the exact same thing you do on the SNOM 370 (and that I do with ekiga for windows) with the product that's the subject of this subforum: "3cx softphone".
    I've 4 different SIP providers that I want to be able to receive call on all of them.
  8. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Use 3CX server to manage and use voip client to call
    any voip client or hardphone connected to 3CX system will do that to you
