Multitech VOIP
Discussion in '3CX Phone System - General' started by telica, May 7, 2009.
  1. telica
    Nov 26, 2008
    9
    Hi All,
    I am trying to configure a Multitech MVP-810 to work with a 3CX.
    I have it all registered OK on Ext 10002 but can not place any calls thought it whether incoming or outgoing.
    I think it is something to do with the "Phonebook" on the Multitech.
    Does anyone have any pointers??
    If you require any more info I am happy to supply.
    Thanks in advance
    Steve
  2. TelicaIT
    Nov 28, 2008
    33
    I have not (somehow) got the 3CX to see the calls but still does not ring.
    Logs show:
    11:32:17.478 [CM102001]: Authentication failed for SipReq: INVITE 4001@10.10.21.200:5060 tid=599738664 cseq=INVITE contact=MultiVoIP@10.10.21.202:5060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    11:32:17.478 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:4001@10.10.21.200:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.10.21.202:5060;branch=z9hG4bK599738664
    Max-Forwards: 70
    Contact: <sip:MultiVoIP@10.10.21.202:5060>
    To: <sip:4001@10.10.21.200:5060>
    From: "MultiVoIP"<sip:MultiVoIP@10.10.21.200:5060>;tag=1221492344
    Call-ID: 10121142273272@10.10.21.200
    CSeq: 2 INVITE
    Allow: INVITE, ACK, BYE, CANCEL, REFER, NOTIFY
    Proxy-Authorization: Digest username="MultiVoIP",realm="3CXPhoneSystem",nonce="414d535c004805b174:ccb1a67e95e52fbc946d2444afaee219",uri="sip:4001@10.10.21.200:5060",response="456829849eb6318726384b2f4a1e7b2e",algorithm=MD5
    User-Agent: MultiVOIP/5.09.06.05.09Jan 18 2007
    Content-Length: 0
    11:32:17.478 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 4001@10.10.21.200:5060 tid=599738664 cseq=INVITE contact=MultiVoIP@10.10.21.202:5060 / 2 from(wire)
    11:32:17.306 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 10.10.21.202:5060;branch=z9hG4bK1099146898
    Max-Forwards: 70
    CSeq: 1 INVITE
    Content-Length: 0
    Any ideas?
    Many Thanks
    Steve
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    You must adjust source identification rule to recognize 'Contact: <sip:MultiVoIP@10.10.21.202:5060>'
    Such kind of Contact is not covered by default rules.
    Or, you better set up the device to send virtual line number (10002) in Contact instead of 'MultiVoIP', than it should work with default source identification rules.
  4. TelicaIT
    Nov 28, 2008
    33
    Works like a dream - Thank you very much.
    Now just got to to stop it from keeping the call open when you make an outgoing call and hang up :)
    Watch this space as I will probably be back.
    Regards
    Steve
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,887
    190
    You should use a supported gateway instead of this one. This will save you a lot of time and grief and support will be able to help you.
  6. TelicaIT
    Nov 28, 2008
    33
    Hi Nick,
    I am only using it to save me a few £££'s as it is on my Test 3CX system that I use to learn so is not on my commercial system or any customer sights as I will not stray from Patton.
    Thanks a lot
    Regards
    Steve
  7. joebocop
    Dec 12, 2013
    96
    We are looking at the MVP810 for its ability to handle analog "DiD Trunk" lines from our telco (they are sending "a wink and 4 digits".)
    Does anyone have experience setting these up with 3CX? Do they work?
    Is there a better product available that is 3CX-supported?
    Thank you!
