Music IVR Digital receptionist
Discussion in '3CX Phone System - General' started by Federico Moschini, May 13, 2017.
  1. Federico Moschini
    Jan 6, 2017
    31
    Dear Team,
    I like that when you are connected to the digital receptionist you can also digit the extension and call the extension directly.
    My question is: how to change the default music when after digit the extension you listen "we are transferring to the number you digit".
    The music is very bad and I would like to use the same on hold music we have for all the others extension and queue, etc.
    Best regards,
    Federico
  2. Federico Moschini
    Jan 6, 2017
    31
    Dear 3CX Team,
    No suggestion ?
    Best regards,
    Federico
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Hello there,
    The PBX music on hold can be specified under settings / Music on Hold.
