Music on hold for a group
Discussion in '3CX Phone System - General' started by evosoft, Jun 3, 2015.
  1. evosoft
    Jul 18, 2014
    Hoping someone call help.
    Set up a group - call queuing . Music hold setup and working ok on an incoming call but when you pickup and decide to place caller on hold. The default 3cx music on hold is played.
    Can i change the default music on hold for the groups or on an extension basis when a call is placed on hold. I don't want to to change system wide.
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Let's sort this out.
    Ring Group objects don't have an MOH setting.
    Extension objects don't have an MOH setting.
    Call Queue objects DO have an MOH setting.. used when a caller is "queued"
    The system's MOH setting is for all other uses.. mainly when a call is "held".
    That would include queue calls taken (transferred out to an extension..) and subsequently placed on hold (the system's MOH, not the queue's..).
    The situation described matches the system's design. Else, you can submit a feature request. :)
